Design SuiteAdvanced section viewport properties
Advanced properties define the extents and attributes of the section viewport. Specify them when the viewport is created, or after the viewport has been created; edit the properties from either the Object Info palette or the Properties dialog box.
Finite sections are useful when you want to create interior elevations. For example, draw a section line across a particular room of a building, and set the layer visibility only for the room’s floor to create an interior elevation of only that room. For an even more precise interior elevation, use a clip cube to create the section viewport; the extents are automatically set according to the clip cube's shape.
The X, Y position of perspective vertical section views is at the center of the section line. The Z position depends on the height range selection (finite or infinite).
To specify the advanced properties of a section viewport:
From the Create Section Viewport dialog box or Create Horizontal Section Viewport dialog box, or the Viewport Style or Edit Viewport Style dialog box, click Advanced Section Properties.
Alternatively, select the viewport, and then from the Object Info palette or the Properties dialog box, click Advanced Properties.
The Advanced Section Properties/Advanced Horizontal Section Properties dialog box opens.
For vertical section viewports, click the Extents tab to specify either an infinite section view, or the length, height (elevation), and depth of a finite vertical section viewport. Extents can't be set for a viewport style.
Extents for horizontal section viewports are managed from the Cut Plane and Extents dialog box; see Setting horizontal section viewport cut planes and extents.
Parameter
Description
Length Range
Specifies the length range of the section viewport
Infinite
Cuts the section by an infinite plane
Limited by Section Line Length
Limits the section only to the length defined by the section line
Height Range
Specifies the height range (elevation) of the section viewport
Infinite
Does not limit the section to a Z range; the Z position is in the center of all the visible layer extents in the Z direction
Finite
Limits the display of the section viewport to a range defined by the Start and End Height Z values; the Z position is at the center of the range of specified heights
Extents Beyond/Before Cut Plane
Specifies the depth of the extents beyond or before the cut plane
Infinite
All objects on the indicated side of the section line are displayed
Finite Depth
Displays objects on the indicated side of the section line up to a specified depth (the beyond depth can be indicated graphically by dragging a dotted line on the design layer; see Modifying section lines graphically)
Click the Attributes tab to specify the appearance of objects on and beyond the section plane. Objects on the cut plane can maintain an individual profile, or can be divided into structural and non-structural groups to display them differently according to class settings.
Certain 3D objects can be designated as structural by selecting Merge with Structural Objects in Sections from the Object Info palette. This allows their appearance to merge with other structural objects on the section plane. Merged objects display as a single unit with one continuous fill.
Objects that can be designated as structural
Deforms (generic solid)
Multiple extrudes
Chain extrudes
Cylinders (extrude)
Extruded polygons (mesh)
Subdivisions
Sweeps
NURBS surfaces
CSG solids (add/subtract/intersect/section)
Extrudes
Extrude along paths
Tapered extrudes
Extruded rectangles (extrude)
Meshes
Solids (sphere/cone/hemisphere)
Stair structures (top face, bottom face, front face, inside/outside)
Parameter
Description
By Style/Instance
A graphic indicates whether each parameter that can be set by the viewport style is set to By Style and given a fixed value or set to By Instance and editable in the dialog box. A style may have a combination of both settings, to balance the need for consistency and flexibility.
The viewport's style is set on the Create Section/Horizontal Section Viewport dialog box or Object Info palette. By Style/Instance settings are established by the style and cannot be changed from the Create [Horizontal] Section Viewport dialog box. To edit the style, see Creating and editing viewport styles; editing the style modifies all viewports in the file that use that style.
Cut Plane
Objects on the cut plane can be merged into a single profile, maintain individual profiles, or be divided into groups of structural and non-structural elements (useful for displaying cabinets and walls differently, for example)
Merge cross sections
Merges the sectioned objects' cross section profiles into one profile
Create structural and nonstructural groups
Merges the structural objects' cross section profiles into one group, and the non-structural objects' cross section profile into another, allowing them to have a different class setting
Separate cross sections
Generates a separate cross section for each sectioned object
Use attributes of original objects
Each sectioned object is displayed with the attributes of its original object.
Merge structural objects with same fill: If adjacent structural objects or components have the same fill, merges the fills so that they display as a single unit.
Add profile line: Adds a profile line around all sectioned structural objects in the viewport.
Attribute Class/Structural Class
To control the appearance of the line and fill for the section profiles, select a class from the list of classes present in the drawing, or create a new class. If the suggested Section Style class is selected, it is added to the drawing; its line and fill attributes can be edited from the Organization dialog box.
If Create structural and nonstructural groups is selected, the class selected here applies only to structural elements.
Nonstructural Class
When Create Structural and Nonstructural Groups is selected, specifies the line and fill class for non-structural elements, or you can select New to create a new class
Objects Beyond/Below Cut Plane
Specifies the fill and line type for objects beyond the section plane (for section viewports that display objects beyond/below the section plane)
Fill
Use original
Uses the fill style of the original objects for objects beyond the section plane
Use class
To control fill style, select a class from the list of classes present in the drawing, or create a new class
Line Style
Changes section viewport settings for line thickness and line type
Use original
Uses the line thickness and line type of the original objects for the objects beyond the section plane
Use class
To control line thickness and line type, select a class from the list of classes present in the drawing, or create a new class
Click the Display tab to specify the section viewport display properties.
Parameter
Description
By Style/Instance
Cast shadows of objects removed by section
When rendering, includes shadows cast by objects that are not included in the section viewport, for a more realistic effect (especially for interior elevations).
This parameter is not available for design layer section viewports.
Black and white only
Changes all colors in the section viewport to black or white; this is useful for displaying two section viewport copies on the same sheet layer, with one in color and the other in black and white. However, if the document preferences display setting is black and white, viewports will also display as black and white.
Adjust flipped text
Re-orients rotated and flipped text in the viewport so that it is always readable (regardless of the flipped text document preference; see Document preferences: Display tab)
3D Conversion Resolution
Sets the segmentation resolution for curved surfaces in a section view, regardless of the Vectorworks preferences resolution setting (see Vectorworks preferences: 3D pane). Changing the resolution of an existing section viewport causes the viewport to become out of date; the higher resolution settings require longer update times.
Scale Factors
Changes section viewport display scale settings for lines and line types
Line Weight Scale
Enter a number larger than 1.0 to make the section line weight thicker. Enter a number below 1.0 to make the line weight thinner. The scale value must be larger than zero.
Line Type Scale
A line type could be used for a section viewport if the section is in a class with a line type (in the Attribute Class/Structural Class parameter) or the objects beyond the section plane have been set to a class with a line type (in the Use class parameter). Enter a number larger than 1.0 to make the line weight of the line type sections thicker. Enter a number below 1.0 to make them thinner. The scale value must be larger than zero.
Automatic occlusion culling
Accelerates rendering and uses less memory by removing objects hidden in the current view from the rendering geometry for some projections and Renderworks and Realistic RS render modes. Deselect to see reflections, shadows, and indirect lighting from objects outside the current view.
Viewport properties
Creating section viewports
Viewport styles
Modifying viewports
